Hi! I was dreaming about buying a laser cutter and lamenting how expensive they
Hi! I was dreaming about buying a laser cutter and lamenting how expensive they are specially considering that I live in Brazil, shipping adds a lot to the cost, and Brazilian taxes are insane!
Then I found out yesterday about low cost 40W lasers. Seems like a well hidden secret!
I’m thinking about buying one for myself, and I’d like to know if anyone recommends some specific supplier on eBay or Amazon. I found it on Amazon for US$ 500, and over eBay for a lower price (US$ 389). I’m a longtime Amazon customer though and I fear that eBay may have a harder time with Brazilian customs than Amazon.
There’s one big issue that’s the software. Some units come with different software. I would prefer my unit to work with Corel Draw, and for what I’ve seen on videos this is possible. Which is the best unit for this?
I also noticed that there are small variations in the control panel. Some have digital controls, while other units have analog controls. Is there a big difference between the two?
This took me a long time to decide. Make sure they specify CorelDraw as the other software is horrible. The control panel laser power isn’t important. I have digital but it does the same job. If you can get air-assist (I don’t have this) as this makes the most difference and is one thing most people without want to add.
And be prepared for a damaged machine. A high percentage are damaged in some way. Mine was dented, the fan broke and the laser tube was cracked. They were all fixed, but it was annoying.
Good luck!
Regarding Digital vs knob; I finally decided on going with the knob. After a bit of research, I figured out that an analog knob actually varies the laser power, whereas a digital PWM control, while appearing to do the same, actually PWMs the laser output at full power. I’m replacing the stock knob with a multi-turn pot for finer control.
