Hi, I would love some guidance.
Hi, I would love some guidance. I’m setting out to build a small scrolling ticker. My plan is to connect 8x1m strips to my ESP8266 board. I have experience with the ESP8266 just not with LED strips. From my research using FastLED + this library https://github.com/AaronLiddiment/LEDText seems like the way to go. I did some sketching of the basic wiring and wanted to get a second opinion before I continue.
Also in terms of how to progress, any recommendations? What should my milestones be? After I get one wire connected should I wire additional wires or start working towards text? Just curious how you’d recommend approaching this.
Thanks.
Have you decided which type of LEDs to use? The ESP8266 works best with SPI type chipsets like the APA102 or SK9822 especially if you’re going to use a lot of them… Also I’m pretty sure there was another text based library/add-on posted on here recently.
Well I already bought the LEDs WS2812Bs, hopefully that’s not going to cause too much of an issue. I read a few places about people getting them working. The Ticker won’t be too large (1m).
How many LEDs per metre?
I’d use the parallel output, there was a problem with it but I believe it’s been fixed now. If not the fix is on here somewhere. You’ll also probably need to disable interrupts.
Does my circuit look like a generally good starting point for first testing a single strip?
It looks fine, on my phone, I can’t see which pin you’re using. On the WeMos D1 I use D5, D6, D7 and D8
To answer your questions, its 60led/m strips. I assume I need 7 or 8 rows. However for scrolling text I would assume well less than 50% of the LEDs will be lit at the same time.
As for the pin, I currently have it drawn on GPIO2.
Any guidance is greatly appreciated.
From a data point of view it doesn’t matter how many LEDs are on, just how many there are. As I said, use the parallel output as this cuts the time needed to write data to the LEDs by a factor of 4. This will make a big difference. Use GPIO pins 12 to 15 inclusive. Put a 1/4 of the strips on each pin
