Hi , im a n00b in the reprap  world,
Hi , im a n00b in the reprap world, and i have a issue with my prusai3 X axis, is noice and really dont work only the X axis. I’ve tried changing the pololu, mounting and demounting, more power in the motor, changing the alignment, changing the tension of the band
… I really have no idea why it does not work properly
http://www.youtube.com/watch?v=JxrCiUmUET0
Hmm, could be issues with the bearings? When was the last time you greased them? It sounds a bit like bearing chatter. It also looks as though it’s catching on the rods. Perhaps you might have a rod alignment issue?
im greased yesterday, the rods are new from yesterday too, im look the alignment and is OK :S
Did it work before and recently start having issues, or is it new?
Is new… They work a few times and afther that.
Did you wire it yourself?
Not really is a kit. And the wire are with the motor.
This is my marlin configuration file I hove they help https://www.dropbox.com/s/iu33k1won867vhh/Configuration.h?dl=0
It’s probably the bearings then. My other guess was acceleration but it seems to be doing alright.
Yep, check stepper voltages.
Can you move it by hand without those problems?
I finally found the problem, the motor cable, thank you very much to all, you are amazing!
