Hi, I’m am new to CNC-machining and especially the use of ChiliPeppr. It’s very promising though. The concept is really great!
I have a GRBL setup, and I started to use the /GRBL workspace. I have looked through the community for answer to my problems, and I have not found all answers or the current state of the GRBL workspace.
It seems to me that there is still at problem with the auto-level, where it stops after the first probe. Then I tried using the /imania workspace, here auto-level works like a charm!
But in neither workspace the Eagle PCB import works, is that a correct observation?
Is there a fork, where all things works for GRBL, or is it in progress?
Thanks for at great tool, and I am btw willing to help if I can do anything myself
No, auto-level is broken in grbl and I don’t know how to fix it. Will need someone to step up if that’s going to get taken care of.
As for eagle, /grbl was pointing to an older version, I just mapped it to the latest on github and pushed an update. Eagle works fine on grbl now.
@Mikkel_Stampe you could post back which version of grbl firmware on which hardware you are using. You could also look at any messages you get in the javascript console (reachable via F12 in some browsers) after the first probe from Chilipeppr when it suddenly stops.
@Camilo_A_C it works for me with bCNC ( https://github.com/vlachoudis/bCNC ) on grblshield with grbl 0.9. bCNC is written in python, and works successfully on Linux. However on Windows I had trouble with the serialport comms, and it did not work there at the time for me.
