Hi, I'm new at ChiliPeppr,
Hi, I’m new at ChiliPeppr, I was going to get a 3040 router so I can cut some carbon fiber. I have the design on Fusion360 but when I run the GCode on the TinyG simulator I get some weird paths. I get straight lines instead arcs, and weird moves. When I save as Mach3 file it works on the Mach3 simulator. Is any way for someone to check the code to see if it is just the simulator or i’m doing something wrong.
Angelos
It is the simulator that does not do arcs but it will run fine.
