Hi! I'm trying to print Daniel Norée tires for the f1 and I'm suffering
Hi!
I’m trying to print @Daniel_Noree tires for the #openrc f1 and I’m suffering with the flexible filament.
In the bottom side (2nd picture) (the one that sticks to the bed) I’ve some problems with layer adhesion (the tire has a small fillet where the layer adhesion fails). Also, the top layers (1st picture) are not filling the whole surface.
The settings for the print in the pics are 250ºC hotend, no extrusion multiplier, 0.2mm layer height, 80 mm/s base speed, 3 top/bottom layers, 2 perimeters and 15% infill.
I’m going to make a test print in a couple of days with 5 top/bottom layers, 4 perimeters and 50% infill.
I’ve also changed the config so the extruder is not allowed to perform travel moves outside of the part, so, I hope having a lot less of strings due to retraction.
Thanks
I haven’t seen much with flexible filament yet; despite the issues you’re having, these are very cool.
Top layer looks like either underextrusion or not enough solid layers. Try atleast 1mm for the top and bottom layers and see if that fixes it. Not sure about layer adhesion, but from the looks of the second picture, it seems to be more of an issue of that filet not being cooled quick enough as it’s being printed. Could even just be the nature of flexible filaments, I don’t have experience with them.
@Steve_L thanks! Will try it
@Eclsnowman ​ may have some good advice about printing with tpu
I think you need to print much slower, like 20 mm/s. If you have a bowden printer like me than it is even possible you must go as low a 10 mm/s to get good results.
@Sandra_Dermisek I’ve a double drive gear extruder which it’s suposed to be able to print tpu without trouble.
Tenes que bajarle un poco la temperatura a 215 aprox. fijate que no se licue tanto porque se escurre de la última capa impresa, si la temperatura es muy alta. Con respecto al relleno, a medida que subis el porcentaje te queda más dura y pesada (algo puse en mi sitio al respecto). Para la adherencia use cinta gris sobre la cama y quedo tan pegada que la tuve que lijar.
what about this for the tyres? Only an Idea.
mibenco 72819005 Flüssiggummi Pur, 175 g, Schwarz Glänzend - Schutz und Isolation zum Tauchen und Pinseln https://www.amazon.de/dp/B00TTMKT8S/ref=cm_sw_r_cp_apa_2gVZybKDF8MQ1
This is a print I had running this morning. Sainsmart TPU, 45mm/s, 215C, 1.09 extrusion multiplier, 75% speed on outer perimeters.
0.6mm coast to end, 2.2mm retraction at 35mm/s, 0.3mm z hop, 3mm wipe.
It was printing two tires for the openrc, and zero strings on travel moves.
@Eclsnowman I think the manufacturer of the pla recommends to use 1.15 extrusion multiplier… I have to check the official profile for cura and move it to simplify 3D, but take notes of your settings. Thanks!
@Luis_Diaz ​ I think you’re printing too fast, I print flexible filament up to 30-35mm/s
@MakerGal thanks! Will try to slow down :slight_smile:
@Eclsnowman I’m going to use this settings for the new print. what do you think about?
@Luis_Diaz looks like a good starting point.
