Hi. Inspired by @Thomas Sanladerer,
Hi.
Inspired by @Thomas Sanladerer, i’m trying auto bed leveling on my prusa i3 running Repetier firmware.
I have an inductive sensor mounted, and calibrated according to the hotend nozzle, with an aluminium heatbed.
Configured my FW for the new sensor.
Disabled z-min, removed switch.
Using z-min pin as input for the inductive sensor.
When i try to run the respective gcode,it only tests one place, and then stops.
After this, i can freely move all axis.
Does anyone have a clue? Tell me what info you need, and i’ll get it for you! :slight_smile:
Every now and then, using G29, it will probe the 3 testing points, but not lower the sensor deep enough to to sense the bed.
Start really close to the bed. Too far up and it “times out” on depth
Brook
Are you homing the Z-axis (G28Z) before running G29?
