Hi, is it possible to get the Central Diff Plate A.4 as seperate files
im already started printing it the third time and always one of the parts gets off, so ive to cancel the whole job. would be much easier and less time/material consuming if one could print it one at a time…
thnx
Helmar
you can just load up the STL in blender, select parts you need (shift + right click) and export those to STL
You can split an object in parts within cura or slic3r, if you use those to create ur gcode.
thnx, but im using a replicator2x with makerware. havnt found a good way how to seperate the models from the stl-files. i know slic3r but didnt get it to work yet. ill have a look at cura
Use Blender, Wings3D, or any CAD tool that loads STL files. You can delete the unwanted parts and save them all to different files.
cura works best for me, very simple to use for that task :slight_smile:
thnx a lot !!!
