Hi, Is parallel strip support in 2.1 library? If so,
Hi,
Is parallel strip support in 2.1 library? If so, is the any examples for Due?
Thanks,
Gavin
No and not yet :slight_smile:
Daniel, do you have a release time in mind?
Thanks
I don’t at the moment. I’m spending the next four weeks focusing on an installation I have to have finished by july 4th. Parallel due support is part of that, but I’m running into a number of problems with it, and it is unlikely that it will be releasable before then at this point.
Ok thanks and good luck on installation :slight_smile:
