Hi. Is there an image size limit to Laser Web?
Hi. Is there an image size limit to Laser Web? I get an error a few minutes after clicking “Generate G-Code”. I’m trying to get the overall area to be 550mm x 550mm.
LW works normally if I need the area under 200mm^2.
Running Google Chrome.
Error Message:
RangeError: Invalid string length (http://localhost:8000/lib/paperjs/paper-full.min.js on line 37).
I understand it may be my PC that is out of resources, but I see 20% CPU and 65% MEM usage.
Thoughts?
Hi Peter - thanks for the quick response. I was not able to get a 550x550mm to generate Gcode using Laser Raster. I get the Oh Snap! Chrome message. I was able to generate a 300x300mm Laser Raster.
I even tried another PC with 16GB RAM and same results.
No size limit in LW4!
Thanks guys for checking in… I dont have a problem loading the image. The problem comes when generating the Gcode (click “Generate” button). It goes to 100% and then “Oh Snap!”. I tried Firefox and same results w/o Oh Snap of course.
