Hi Mathias,
How do I set up Gcode Touch to work with my delta printer ? It will send commands but of course only a limited portion of the build area is used ( the +ve in X and Y). Can you help ?
@Jules_Anderson GCodeTouch3D allows you to configure rectangular print beds only. The size can be configured in the options (Printer section). I hope this helps.
It’s not the shape of the bed, its the starting point ( I think )
Where a standard cartesian X0 Y0 is in the corner of the bed, on a delta this position is in the centre…
Can you perhaps code in an option for offsetting the home position?
ah, I see. I can certainly add an offset option. I will try to do it next week.
Thanks ! Keep up the great work !
