Hi people need help here with retraction. It’s doing this rough noise when retracting at 70mm/s length 6mm
When it’s printing it is quiet only when retracting… I wanted to try 100mm/s retract speed to eliminate stringing but can’t bear the sound it made at 70… Any suggestion? Thx
I was having some retraction problems with wood pla at 100mm/s for 4 mm. Grinding away filament changing the thickness of it as it went through the the hot end, and a band grinding/honking noise. I dropped retraction settings to 3 mm @ 50mm/s and my horrible sounds went away, no stringy problems. What are you printing with?
Try printing a little cooler like 190 and slow that retraction down. I had problems with wood PLA as well. the recommended retraction settings I was seeing online for wood pla were VERY reserved. i was seeing things like 2.5 to 3 mm at 20-30 mm/s.
@Step_Cia I retract 5mm at 45mm/s. I have almost no stringing anywhere, but I have not used a wood fill before. Do you have the same issue when printing in regular PLA?
Yeah, that should help a lot. Like I said previously, try 192. It seems the be my sweet spot for minimal stringing while still having good layer adhesion.
hmm did various speed test and found that 35mm/s retract is the fastest retract speed without making that noise… upping current and acceleration didn’t seem to help
sounds similar to what I experience with my wood pla and from what i was able to drag up online. Im thinking the wood pla is just softer and too much acceleration on the retract is grinding the soft filament instead of bringing it back. How is your stringy ooze problem?
ok. did some more test. this time I stripped out the Titan and just left with the E motor clamped. it turns out the TMC2100 in stealthChop mode can’t handle retraction speed faster than 35mm/s so I disable stealthChop (yeah it is now whining…) but I was able to retract at 70mm/s now. Could be more… I did not want to push it more.
