Hi,
Still sorting parts here.
I’m a little lost with all these smoothie-based board.
I prefer to have an LCD but it seems that the smoothie isn’t so much friend with the viki2 and adapter boards will not be available soon (or never).
In the other end Azteeg X5 looks good, Do you recommand them over the smoothie ?
Is there an other “ultimate board” that I am missing ? Rumba ? Others?
Well there is Ultratronics which is new and runs Marlin (not smoothie based)
https://reprapworld.com/?products_details&products_id/1177/cPath/1591_1750
then there is this adapter for using GLCD on the Smoothie
http://robotseed.com/index.php?id_product=23&controller=product&id_lang=2
@Maxime_Favre I use Smoothieboard together with Viki2 without any problems. If you disable onboard LEDs on the Smoothieboard then you can use all features of Viki2.
For that you need to solder the headers on the board and connect the Viki2 cables to it as you like. Then you just put in the config file the pins, where you connected what.
if you need, I can give you a sample config file and some photos how I connected it.
@Hakan_Evirgen Ha ! Sample config and some wiring pics would be welcome ! (and maybe added on github ?)
I don’t have one but: https://groups.google.com/forum/m/#!topic/smoothieware-support/yz59HdNxGC4
Yeah I just found this link too, thanks.
I think I’ll go for the smoothieboard. Sadly there’s no smoothie-based board compatible with TMC2100 drivers ;(
If you only plan for a single extruder the X5 mini V2 is a great option.
Dispite the extruder limitation, price and ethernet, is there any advantage of one vs the other ? Stepper performance ?
Sorry for all these question, it’s hard to find any comparison.
The X5 is much smaller and allows you to select microstepping all the way from full-steps to 1/128 microstepping. Plus the pin arrangement is a bit more aesthetically pleasing and the viki2 connects to it with a simple wire harness
I think you convinced me
Thank you
Everything is ordered except misumi, I still need to source some screws locally
screws from the place referenced in the BOM is great.
@Jim_Stone Yes BOM is really great to work with. I ended to order screws by McMaster. Prices+Shipping are just insane compared to Switzerland’s prices ô0
Now printing…
@Maxime_Favre at the moment I am busy to search and compile the Viki2 config+photos. Remind me in a week or two and I will do so.
have a look at http://www.thingiverse.com/thing:745001
i use it on my herculien and it works fine with smoothieware, & the display you can order with it is just 25$
