Hi there if anybody is interested in some Relay Mounts here you go!  http://www.thingiverse.com/thing:1287530
I don’t own a 8 channel yet. I will work on it in future. also I don’t have plans on a 16 version. But cable tie attachment future work in progress.
What I really want is a 6 motor driver that can be BT controlled without slapping an Arduino solution together. I have the 8 relay board but would love to see something more OOTB. I know off topic, but if you guys know something…
Why do you need it?
It’s not like the PCB doesn’t have mounting holes already.
@Marcus_Wolschon Are you kidding me? So your telling me that you would mount a pcb board directly to any surface? Especially some relays? Then if your dumb enough to do that. Then PLEASE go and learn!
As long as the surface is not conductive. Sure.
Usually mounted to wooden enclosures or frames that hold the devices the relays control.
Guess where the name “breadboard” came from.
In a plastic enclosure, the usual way would be to atach spacers to these holes and mount the spacers to holes in the plastic.
@Marcus_Wolschon Good luck with your “concept” because that WON’T HOLD or SUPPORT it! I’m NOT here to argue though Marcus. Just posting my project I made to HELP people that want a Relay Mount with support! THANKS.
