Hi there. I'm stuck with an extruder problem on my Hephestos 2 printer.
Hi there. I’m stuck with an extruder problem on my Hephestos 2 printer. Since I upgraded my Hephestos 2 with a heated bed the gear of the cold end seized to work (see video). My supplier already tested the complete extruder on his Hephestos and he had no problem. Any ideas?
https://drive.google.com/open?id=0Bwg0RBbuN0fMUV9CR2xtQzl1OTg
seems to be a broken cable or a wrong wired motor. The motor is jumping between two fullsteps. Check your wiring with a multimeter.
@Kai11 You’re a life saver. Replaced the cable today and the problem was gone. Thanks man.
Glad to hear that I could help.
