I want to run two APA102 strips off the same controller, but I want to use different data/clock pins as I wish to run them as independent strips, off their own digital i/o pins.
I have the following code, but I realised that perhaps I cannot define more than one data/clock pin using FastLED. Is this possible?
I will give it a go tomorrow at college. I am attempting to interlace two strips showing every other online of an image from two predefined arrays (that contain every other line manually sorted beforehand).
Will be in POV globe. I have one strip already working, but would like the second for more resolution vertically.
If this works can I add more strips again in the same way?
Hi, thanks again for your advice.
I have successfully got my strips to work with the above code.
I am now struggling to cause a delay to the second strip (so that they are synchronised when I spin them)
Is it possible to add a delay?? I tried to follow the advice in the multiple controllers example, but am struggling to write the correct usage into my code properly.
Examples:
My code:
void pushImage(unsigned long time, const unsigned int array[]){
unsigned long currentTime = millis();
while (millis()< currentTime + (time)) {
int f= numberOfSlices; // counter for ‘horizontal’ LED (strip is spinning)
int z; // Counter for which vertical LED
int j=NUM_LEDS; // total num of LEDs in strip
for (int x=0;x<f;x++){
for(z=NUM_LEDS;z>0;z--){
leds[z-1]=array[x+((j-z)*f)];}
FastLED.show();
delayMicroseconds(335);
