hola compañeros espero estés bien. quisiera saber tres cosas: 1.
  1. ¿que software puede ser usado en la impresora ANET A8 como lo son (cura , repetier) que otros se puede usar?
    2¿que software es el mejor para la generacion del gcode?
Did you forget to type your third question?
The Anet A8 runs Marlin firmware so you can pretty much use any slicer (software) you want. A good place to start is Curra because it’s good and is easy to use for beginners.
The best software is arguably Simplify3D but that costs $150.
@Adam_Steinmark
Thank you very much, that’s what I needed to hear
