I defined my endstops and they work correctly. If I select Prepare, Home all axes from my GLCD menu it works as designed. Homing against endstop , retract 5mm and home again at low speed untill it hits the enstop.I expected that a G28 would produce the same but is only moves the axes to the place of the previous home cycle. I would like to have the G-code that does the same as the selection in the display.
Is there a G-code for this ?
Regards
Dirk
Ps: Running the latest edge.
