Hope to jump on the #LaserWeb bandwagon soon. ![]()
Yesterday I assembled a cheap Bangood laser engraver kit and was able to produce nice results with the Benbox software.
But that was yesterday.
Today I downloaded the LaserWeb windows installer from +Peter van der Walt, flashed the grbl 1.1e and got the connection with LaserWeb. Then I got some issues:
The laser seems to be on by default (without hitting “run”)
When I move the head in the X-axis, it travels more than the 1mm (in Jog mode). Do I have to calibrate it via console or can that be done by LaserWeb?
It says: : “MISSING CONFIG: You need to configure LaserWeb for your setup…” But I inserted all required values…
Any ideas what I can do?
WebGL Support found!
success:
Laserweb will work optimally on this device!
: Jog will use 1 mm per click
: Running from Electron Backend
: Checking whether you have configured LaserWeb :
: Found setting: rapidspeed : 100
: Missing optional setting: subnet1
: Missing optional setting: subnet2
: Missing optional setting: subnet3
: Missing optional setting: wifisubnet1
: Missing optional setting: wifisubnet2
: Missing optional setting: wifisubnet3
: Missing optional setting: smoothieIp
: Found setting: laserXMax : 400
: Found setting: laserYMax : 300
: Found setting: spotSize : 0.2
: Missing optional setting: startgcode
: Found setting: laseron : M3
: Missing optional setting: laseroff
: Found setting: lasermultiply : 1
: Found setting: homingseq : $H
: Missing optional setting: endgcode
: Found setting: lasertestpower : 10
: Missing optional setting: lasertestduration
: Found setting: imagePosition : BottomLeft
: Found setting: useNumPad : Disable
: Found setting: useVideo : Disable
: Missing optional setting: videoSource
: Found setting: cncMode : Disable
: Missing optional setting: webcamUrl
: Found setting: defaultDPI : 24
: Missing optional setting: illustratorDPI
: Missing optional setting: inkscapeDPI
: Found setting: defaultBitmapDPI : 96
: Found setting: airAssistAttached : Disable
: Found setting: materialThickness : 1
: Found setting: cuttingMatThickness : 1
: Missing required setting: zFocusHeight
: Found setting: safetyLockDisabled : Disable
: Found setting: optimisegcode : Disable
: MISSING CONFIG: You need to configure LaserWeb for your setup. . Click Settings on the left, and work through all the options
: Version currently Installed : 30476
: Version available online on Github : 30476
: Your version of LaserWeb is Up To Date!
: DXF Opened
: Processing my-drawing.dxf
: Gcode Data Generated for my-drawing.dxf
: Preparing Gcode File: my-drawing.dxf
: Estimated Distance: 0.7 m
: Grbl 1.1e [‘$’ for help]
