Hope you are all having an enjoyable Memorial Day weekend!
I am Oxing this weekend. I posed some problems that I was having with Motor heat and Tinyg some of you responded with ideas that I implemented and I thought I would bring you up to date.
This is really getting frustrating as I spend more time troubleshooting than cutting. After a successful day or two last week, I started to cut some parts yesterday. Immediate failure twice with good ole Tinyg blinking the red LED. Both times the part failed during the making of hole 4 of 27. A really simple part actually, drill 27 round-bottom holes in a piece of pine.
So, after the changes I made last week, which I thought solved my Tinyg blinking problem (moving sensor wires away from motor wires) didn’t really solve the problem. This time I turned off all six limit switches. To my joy I was able to make 20 pieces of my project (27 holes each) however, while making piece 21 I am back to the blinking LED - Frustrating as hell.
I used to be concerned about my OX accuracy, now I am more concerned about reliability of the components. I have no real idea why Tinyg blinks the LED, perhaps someone can list the reasons. I’ve heard bad gcode, hot drivers, etc. I’m not even sure it’s a Tinyg issue, maybe Chilipepper is not delivering gcode properly. Too many moving parts I’m afraid. Will TinyG start the flashing LED if it is starved for code?
Is anyone really running any significant projects with the combination of TinyG and Chilipepper? I mean my project is really simple, takes about three minutes to drill the holes, then I repeat. If I were running a longer project I’d be really concerned about it actually running long enough to complete - at least it’ good for material suppliers as I get to waste more boards!
If TinyG fails when it gets bad gcode, how often does Chili pepper deliver bad code? Or does it? Is this a buffering issue? Does anyone use something other than Chilipepper? Something that is not web dependant? Don’t really need the viewer, nice but my CAM software does that.
Sound like I’m frustrated? Yep! Don’t mind troubleshooting sometimes, in fact I like it. But not everyday. I need a more reliable machine - yes and it is a hobby. I keep hearing that TinyG boards are being used more and more in production machines. Really? The must know something that I don’t (Quite likely) Any Help would be appreciated.
Many thanks,
Ted
