How can I create a smooth color fader animation with FastLED functions?
Hello, I want to create a simple color fader that just moves through each color via the HSV color system. Currently I am doing it this way:
loop() {
fill_solid(leds, NUM_LEDS, CHSV(hue++,255,255));
delay(…);
But it makes the animation look choppy at slower speeds (with a delay). I would expect the occuring colors to be something like the following:
rgb(255, 0, 0)
rgb(255, 1, 0)
rgb(255, 2, 0)
rgb(255, 3, 0)
but instead they are more like this (I didn’t test the exact values but the increments are much bigger like you can see):
rgb(255, 0, 0)
rgb(255, 4, 0)
rgb(255, 8, 0)
rgb(255, 12, 0)
Obviously the first method would give me a much smoother animation while I would have to adjust the speed.
Is there a FastLED function that I can use to replicate the upper behaviour without coding it myself? If not, what would be the easiest way to do it?
Thank you!
