How come when using corellaser, when I do a cut, each cut happens twice?
How come when using corellaser, when I do a cut, each cut happens twice? If I were to cut a square, it goes down each side twice?
Change your line width to .001
happens with laserweb too if line width is not .001
OK I know Im a newbie to this kind of thing. But for the life of me I cant find a place to set line width!
@greg_greene There was a bit of a discussion about that recently for LaserWeb whereby I think the line width was only making that happen when the SVG was less than version SVG1.1. Although, you may be referring to a different file format.
@Bob_Damato You may have to enable the correct panel in Corel Draw first to allow you to access the line width. Or, you can customise a toolbar by adding a line-width button.
Here’s a screenshot to maybe help: https://drive.google.com/file/d/0Bzi2h1k_udXwZ3h0UmhkUW1vUnc/view?usp=sharing
@Yuusuf_Sallahuddin_Y Thank you! yes I definitely dont have that! Lets see if I can get that up there, thank you!
Your correct Peter - I was thinking of LaserDRW - but put down LaserWEB which I hope to move to soon !
Look for “stroke” in the Help
I have this same issue, only it’ll go 5 or 6 times, I export in Fusion 360, and I am not sure if I can set a line width in there. Is there a easy way to edit a file afterwards and adjust it?
