How do I get laserweb4 to see the Xmin/Ymin as the top left corner instead of the lower left corner of the laser cutter? I don’t see it as an option on the left hand side.
OK, I hadn’t looked for a way to change the home to max, just found it in the smoothie config file, I’ll mess with that the next time I go to the hackerspace. Looks like I may have to rewire the Y axis motor to get it to go in the right direction.
Awesome, thanks for the help, I am updating the config file now in our github repository, so that I can just grab and go next time I am at the space. Still need to wire up the laser but last time we worked on getting this going we were having endstop issues, which we finally solved today.
Also, with smoothie you (usually) don’t have to rewire to change direction, just negate the direction pin by adding a ! to the config line…
@CescoAiel sweet, did not know that! Thanks!
