How do I know what version of Redeem I am running? M115 outputs this:
M115 outputs this:
Send: M115
Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Redeem FIRMWARE_URL:http%3A//http://wiki.thing-printer.com/index.php?title=Replicape MACHINE_TYPE:Mendel EXTRUDER_COUNT:2
Can you ssh into the BBB?
Systemctl status redeem
It’s most likely an older version then, 1.1.5 perhaps?
Here is what I get:
root@kamikaze:~# systemctl status redeem
  • redeem.service - The Replicape Dameon
    Loaded: loaded (/lib/systemd/system/redeem.service; enabled)
    Active: active (running) since Thu 2016-02-18 00:04:55 UTC; 3min 48s ago
    Main PID: 278 (redeem)
    CGroup: /system.slice/redeem.service
    |-278 /usr/bin/python /usr/bin/redeem
    |-522 socat -d -d -lf /var/log/redeem2octoprint pty,mode=777,raw,echo=0,link=/dev/octoprint_0 pty,mode=777,raw,echo=0,link=/dev/octoprint_1
    |-524 socat -d -d -lf /var/log/redeem2toggle pty,mode=777,raw,echo=0,link=/dev/toggle_0 pty,mode=777,raw,echo=0,link=/dev/toggle_1
    |-526 socat -d -d -lf /var/log/redeem2testing pty,mode=777,raw,echo=0,link=/dev/testing_0 pty,mode=777,raw,echo=0,link=/dev/testing_1
    `-528 socat -d -d -lf /var/log/redeem2testing_noret pty,mode=777,raw,echo=0,link=/dev/testing_noret_0 pty,mode=777,raw,echo=0,link=/dev/testing_noret_1
Feb 18 00:05:08 kamikaze redeem[278]: 02-18 00:05 root INFO Added fan 0 to M106/M107
Feb 18 00:05:08 kamikaze redeem[278]: 02-18 00:05 root INFO Ethernet bound to port 50000
Feb 18 00:05:08 kamikaze redeem[278]: 02-18 00:05 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
Feb 18 00:05:09 kamikaze redeem[278]: 02-18 00:05 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
Feb 18 00:05:09 kamikaze redeem[278]: 02-18 00:05 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
Feb 18 00:05:09 kamikaze redeem[278]: 02-18 00:05 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
Feb 18 00:05:09 kamikaze redeem[278]: 02-18 00:05 root INFO Redeem ready
Feb 18 00:07:16 kamikaze redeem[278]: 02-18 00:07 root WARNING Heater time update large: H temp: 0.0 time delta: 110.6438241
Feb 18 00:07:16 kamikaze redeem[278]: 02-18 00:07 root WARNING Heater time update large: E temp: 21.4333 time delta: 110.643247128
Feb 18 00:07:16 kamikaze redeem[278]: 02-18 00:07 root WARNING Heater time update large: HBP temp: 21.4333 time delta: 110.893690109
Apt-get update Apt-get install redeem
Needs moar lines! Add “-n100” to see the whole output. Should be the first log line.
Yes, it was old. Thanks Zachary Jeffrey. Updated to 1.1.8 and I couldn’t start redeem because of an error due to the motor decay values in my printer config file that were set to “False”. This version of redeem was expecting “0” instead.
