How do I set the paths order in Autocad DXF?
I want the outer contour to be cut last.
I’ve tried to use the Back/Front thing but no difference, not like the AI tutorial I’ve seen down here.
It seems it’s only controlled by which path was edited/created last.
Do you know if Autocad has some sort of Linux’s “touch” command? So I can update the paths in the order I want them cut. Or another simple way to alter the cutting order of a DXF?
Many thanks.
+Peter van der Walt beautiful as always. Thank you. Until then do you know by any chance if it can be done in Autocad before saving the file?
