How do I update laser web, I typed CD Laserweb; chmod +x update.sh; ./update.sh
Said chmod not recognized?
Awesome thank you, I had asked a question a while back under another blog about #define laser_PWM xxxxxx // HERTZ because laser performs differently when this value is not set correctly for whichever program being ran ie laser web, inkscape plugin, j-tech, imag2gcode etc. After digging and digging I couldn’t find much of an answer so I decided to play with inputs based on code being used in Marlin and gcode files. I ended up using (50000/2) // HERTZ and seemed to work but I have no way to know for sure since I’m clearly not a code guy. Some programs would only work at 25000 HERTZ while others required 50000 HERTZ. Did I do right, did this fix the issue or mask it? Just don’t want to hurt the laser or process by just changing in and out numbers i know nothing about. Also getting low memory error from all the added bloat in the firmware left over from modded 3dprinting firmware. Thanks again
Which board specifically and is the mod much different than what I have with Marlin or will it be plug in play ?
Checked out boards on ebay there are several types which do you suggest and will it connect in the same way the ramps did?
