How does one setup multiple pass cutting on the laser.
How does one setup multiple pass cutting on the laser. K40 with coreldraw/laserdraw
Thanks
Oddly Enough, I’ve yet been able to figure this out myself (atleast not accurately).
My google-fu hasn’t been good. Not one good answer found yet.
Hopefully somebody else here has the answer.
Could it be as simple as just running the design 2 or three times in a row without moving the target material on the cutting bed?
I use the “repeat” command but after each pass, a dialog box pops up on the screen and you have to press OK for the next pass to start. I would like to find a way that it will do all passes consecutively.
This is the work around I found this morning. For each pass you want, add it as a task. So for three passes, add task three times and press start.
