How much Z travel?
How much Z travel?
I’ve got a couple of ideas bouncing around in my head for an adjustable Z table with a flat top (no threaded rods poking up) but the mechanism would eat up some of the height.
What amount of Z travel do folks find useful? I’m primarily expecting to compensate for different thicknesses of sheet goods. I’d remove the Z table for larger objects or to place a rotary attachment.
I cut a hole into the button for the Z Table, so i could put a chest or some similar in it.
For most things you typically only need up to 25mm (1") of travel. This covers cutting / engraving on 3mm to 6mm sheet goods and Engraving on 25mm boards. 50mm would be even better. To be sure I also do things that range all the way down to the floor of the laser for engraving large objects. But 0-25mm covers 90% of things I work on.
…for sheet goods you only need the thickness of the material?
This design does not use an adjustable table, rather it clamps the sheet goods below the focal point.
@Scorch came up with the idea and built one and this design was derived from that. I have all the parts but its in que to build.
@Scorch has certainly come up with an elegant concept. Knowing myself and my propensity for pushing to the limit, I expect I’ll eventually want to try multiple passes to cut thicker materials, so I’ll want to lower the table height without shifting the position of the material in the X or Y directions. I promise to share the idea as soon as I get a model pulled together.
There have been a few scissor lifts tried but as you point out, there is not much room for adjustment. It is hard to have our cake and eat it too!
