How to add Rotate Axis (4th Axis) to smoothieware CNC?
Good afternoon. I need your help.
Board has 5 stepper drivers.
It is stupid to use only 3 of them.
  1. Can I connected in parallel two stepper motor driver for two Y-axis?
  2. Can I connect 4 axis?
  3. What software do you recommend for generating Gcode and transfer it to the machine? It would be easy to use software.
Hey.
  1. http://smoothieware.org/cnc-mill-guide#toc27
  2. You’ll have to use the Extruder module at the moment, it provides the same functionality.
  3. This could be a good beginning : http://smoothieware.org/software
Cheers.
