It would be appropriate to make a new post instead of derailing this one.
You can post to the Cohesion3D Community here on g+.
How big of a machine are you building that you need 6-8 amp drivers?
I used the drv8865 drivers on my printer and they got hot as fire. I have had to switch to a different controller.
Right now, I’m thinking 1000 mm by 1500 mm. My concern is the motor I bought for the z axis (a NEMA 34). I keep vacillating about the design.
Yes, from the looks of it, I like the remix option.
Smoothie is a good board
I’ll check it out when I’ve reached a little further in the build. I may get one for one of my 3d printers, if I can ever reach that learning curve level.
Just viewed your group. Good stuff!
Hello. First of all thanks for great tool for milling!But I have a little trouble with Auto Levelling:
I used “http://chilipeppr.com/grbl” page.
Configure system for AutoLeveling every 2mm->AutoFill and start all it and when it done I press “Send Auto-Leveled GCode to WorkSpace”.
Hare is my problem:
When I used simple pcb GCode in a tick I get (al new z) comment in my GCode box, but if my pcb GCode is massive and I press “Send Auto-Leveled GCode to WorkSpace” nothing to happened. I press “Send Auto-Leveled GCode to WorkSpace” several times before I get it comment (al new z). I thing it delay before GCode is reconfigure all my Base-Code with Auto-Level code. But I haven`t any progress bar, and press it again and again before I get it comment.
Can you create some status bar for it? Case I wont use more large project in future. And no idea how many times I must wait before I can star milling)
Just wait a few minute and press “send auto-le…” again
Found what the problem is, the comment is not always added to the first appearance of Z in the GCode, auto-levelled files are created normally, I just did not see they , and the ‘View Auto-Levelled Gcode’ button is just not working)
The comment does not always appear here, therefore I panicked)
when I closed the browser
Do you use CryEngine 3?
