How to Control a 3D Printer Extruder
I am trying to control a 3D Printer Extruder that I got online. I know that for the most part, a person would just plug this in to a circuit board and it would just work. I want to make my own circuit board to control it. I have the DC12V K-Type 0.4mm Nozzle Extruder Print Head Thermocouple For 3D Printer from Amazon.com. It obviously runs on 12v but I cant get any more info then that. I know how to control the stepper motor and the fan (assuming it runs on 12v) but as you can see there are 4 wires coming out of the hot end. I assume 2 of them are to a heating element(maybe the fabric ones) and the other 2 go to a thermistor or some sort of temperature sensor. I just don’t know how many volts to put into the hot end, how many amps does it consume, and how I can get readings off of the temperature sensor. I want to hopefully do this with an Arduino and I would also assume that some circuit would have to be built in order to get the proper voltage to the hot end and fan. If at all possible could anyone please answer some of these questions and possibly draw me a schematic of what I would need to do in order to achieve my goal?
Thanks.
Hey.
The fact that it says “K-type” in the name means it’s a thermocouple, not a thermistor.
You can read http://smoothieware.org/temperaturecontrol to learn about how to talk to thermocouples.
Appart from that, http://smoothieware.org/3d-printer-guide should have all the information you need.
Cheers.
