How-To: DFRobot “Beetle” + AA power
This short photoset shows how to combine the DFRobot “Beetle” and the DFRobot “AA Boost” battery pack (with just a little pin-bending) into one compact, portable LED-driving platform for under US$15.
https://www.flickr.com/photos/kriegsman/sets/72157647377779280/
This is exactly how I made about half of the “Aurora Lanterns” for Burning Man 2014. The other half used 3xAA or 4xAA battery holders, also from DFRobot, all links below…
Beetle: The DFRobot Beetle is a small, cheap (US$7.90), easy-to-solder, Arduino Leondardo -compatible (ATmega32U4) microcontroller.
http://www.dfrobot.com/index.php?route=product/product&product_id=1075
AA Boost power adapter: DFRobot also makes an AA Boost module (US$5.90) that holds two AA batteries (very securely), and steps the power up to 5V.
http://www.dfrobot.com/index.php?route=product/product&product_id=991
Also of note:
3xAA-to-MicroUSB battery pack (US$1.60). No switch, but it plugs directly into the Beetle’s MicroUSB port! You can easily cut one power lead and install a switch in-line. Super easy, and the 4.5v power is fine for the Beetle and the LEDs.
http://www.dfrobot.com/index.php?route=product/product&product_id=1130
And finally,
4xAA battery pack (US$1.30), with switch and leads. In my personal experience, the “6v” (a bit less) output here is ALSO fine for the Beetle and the LEDs – although it’s potentially, technically not ok. I built several lanterns using this, and they all worked just fine.
http://www.dfrobot.com/index.php?route=product/product&product_id=202
I used the 3xAA and 4xAA for larger lanterns or things where I needed the extra mAh. But for lots of projects, the 2xAA module is just great, especially with the pin-bending + Beetle trick.
