I want flashing bootloader using FlashMagic, but i can’t boot board into ISP mode.
Can you help me?
Thanks very much!
Can you help me?
Thanks very much!
Does the board have an ISP or Bootloader button ?
The board is not open-hardware so I can’t really give you much help with it, I recommend you contact the seller.
The board doesn’t have ISP button, but it have i pin for ISP.
I have a board’s schemetic, but i don’t know how to insert image.
ISP goes to pin 2.10
Then the process to get into bootloader mode is going to look something like this :
That should do the trick
Why do you need to flash the bootloader by the way ? That’s not something people usually need to do.
Hi arthurwolf
because i want to flash firmware via usb cable instead of sdcard.
if use sdcard, sometimes user delete some file such as firmware.cur, config, etc. Then board will not use. So i want to flash the firmware to the FLASH memory of MCU.
I tried your method, but board can’t enter ISP mode.
When i release reset button, the board work normally.
I use Flash Magic’s terminal then type dfu command, the terminal display “entering dfu boot mode”.
But when see Windows Device Manager in COM port warning ! “smoothie”, that mean smoothie driver is wrong, althought it work normal in normal mode.
where i can find smoothie driver?
DFU is for linux only, won’t work with Windows.
Also, I don’t understand what you mean about needing to flash the bootloader : the bootloader is already present on your board, you don’t need to flash a new one …
Thanks arthurwolf
Because i want to flash firmware into board via usb cable instead of copy to sdcard.
Were you able to get this to work? I’m struggling with it now
