how to speed laserweb in eleksmaker?
No sure what you mean. Please explain
The max axes feed can be configured by Grbl settings $110 - $112 and accelleration by $120 - $122 (see https://cncpro.yurl.ch/documentation/initial-configuration/31-grbl-1-1e)
The max feed is used for travel moves. The feed for engraving or cutting moves is set with “Cut Rate” in LaserWeb4, but be aware that the low laser power is mostly the limiting factor.
