How would u wire up the board to power when using an external ps but keeping the original for the laser ps?
Stepper and endstops wired into external PSU. Can you identify those?
I’m using C3D mini board
So you have already everything connected to it, the just change the board input voltage to the external PSU
@Ariel_Yahni_UniKpty what about the power for the laser? It’s still powered by the stock psu?
@William_Kearns laser power itself never goes through the board ( any board ) that goes directly to the tube
@William_Kearns , please see the C3D Documentation link. I posted a lengthy step-by-step instruction how to wire two external drivers and steppers. The wiring will be the same as what you are trying to achieve here.
