https://www.youtube.com/watch?v=1EjgXNM6KWw I have been working on my Halloween pole for a few weeks now.
I have been working on my Halloween pole for a few weeks now. I started with a little knowledge of arduinos but almost none of FastLED. A big thanks to the great community of folks here who helped me get the project working. I look forward to trying even more advanced stuff with FastLED.
My pole has 300 WS2812s wrapped around an aluminum shower curtain rod, which is in turn inside a plastic tube usually used to cover fluorescent lights. To make the plastic tube more rigid, I designed and 3D printed a “slinky” that had an inside diameter that matched the aluminum tube, and an outside diameter that matched the plastic tube. I wrapped the entire length of the staff with that coil, and now the whole thing feels really solid.
The pole basically plays four animations from the demoreel100 - fire, confetti, cylon, and juggle - plus a pulsing animation I created. All except the fire animation have custom palettes attached. The animations are cycled through with a button press, but in this case, the “button” is a wireless relay panel, so the animations can be triggered remotely. There are four relays - two go to the arduino nano controlling the pole lights, and two go to another arduino nano controlling the skull. Only one of the relays is in use right now, to change the patterns, but everything’s wired up to allow expandability. One of the relay buttons triggers a camera strobe, which is mounted inside the skull.
The pole is rechargeable - I dismantled a USB powerbank, designed and 3D printed carriers to put the batteries inside the tube, and then designed a cap that contains the charging board, the two nanos, and the main power switch, as well as the relay panel.
As a FastLED project, this is pretty simple - I mostly used existing code for the animations, button selection, and palettes - but it’s a pretty solid build, and I’m pretty proud of it for a first effort. Thanks again to everyone who helped!
@Karl_Tinsley ​​ nice job! Well done.
The removable skull is a good idea!
The remote control is a great idea for that “flash” surprise, triggering it just as someone gets too close, while you stand idly by :wink:
You will get some interesting effects if you light every nth led a given colour. I.e light the 1st led leave the next 4 black light the 5th led, leave the next 4 black and so on.
You will have to experiment a little to find the right spacing for your staff, but you will get rotating veritcal stripes along yhe full length of the staff.
Also, have you tried a strobe affect with the leds? Pulsed on full white very briefly they are amazingly bright. Possibly putting out a percieved brighter flash than your camera flash.
Enjoy the holidays and thanks for sharing.
Stuart
Awesome job Karl! Whole thing looks great. I dig the use of the external button controller and hidden flash surprise.
@Karl_Tinsley - Great build! Even more so considering this is your first project.
