I am banging my head against the wall trying to make the ChilliPeppr logo to come out correctly, and other simple item like circles. First, let me clarify I got the bug watching all the neat thing you guys are making with ChilliPeppr and inexpensive CNC, I had to make one. I build an OX CNC 1000mm X 1000mm. But I am new to this. I am using a TinyG v8 to control the hardware. Before that I tried Grbl v3 with an Arduino Uno and got the same results with both. I can send the CP logo 20 times and it repeats exactly the same. I send it at 2x, 5x and even 8x and the output is the same.
Below are pictures of the CP logo, a dust boot I tried to make and my new CNC. Any help will be much appreciated.
I can post my TinyG configuration and any detail required to help me troubleshoot my problem, if someone is willing to help.
+Phil, thanks I enjoyed building it. The first real test was on MDF after John’s recommendation but so far same results.
+Alex, Yes, I have done 3 side by side even different router bits and no improvement.
+John, the belts are as tight as they can be. There is no backlash and no slipping on them. Included in the link is a pic of the XY axis. If you look closely the belt on the X axis, it wraps around the pulley 180 deg. I think I am going to change the X axis stepper try it and if no change then the Y axis. Y/N?
