I am checking out the dual extrusion abilities of Cura.
It looks like I can adjust the effective flow ratio of each nozzle by tweaking the filament diameter.
I can control the temperatures individually.
I think Basic->Support->Support Dual Extrusion chooses which nozzles to use for the support material. Is that right?
Is there any way to control what nozzles are available for the main print or is it via the Basic->Support->Support Dual Extrusion and any nozzle not doing support material is the main nozzle? I do not know what would happen if you say “both” or “none” for that item.
It looks like you sett he x,y offset of the nozzle via File->Machine Settings->Extruder 2.
Thanks in advance for any info you guys can provide.
Weird. I did strike throughs.
