I am having a weird problem...I have no shutdown or reboot command from root!
I am having a weird problem…I have no shutdown or reboot command from root! Any ideas?
root@kamikaze:~# reboot
-bash: reboot: command not found
root@kamikaze:~# shutdown
-bash: shutdown: command not found
Is this on Kamikaze 2.0.7? There have been a lot of problems with that version.
No this was on 1.1.0
It sounds like your system was corrupted, even on 1.1.0 I had those commands. Try doing an ls /sbin and ls /usr/sbin to see if the commands exist? If they do is a problem of your PATH variable being incomplete
System was corrupted, reflash fixed! Thanks
