I am running Chilipeppr on both a Windows 10 machine and a Mac OS X machine. I am able to connect the Arduino on both machines, however the motors will not move on the Windows machine. The motors work fine on the OS X machine. Any thoughts on what might be causing this? The motors sound like they are trying to move but there is no movement. Chilipeppr also shows that the motors are working.
Are you using Grbl or TinyG? Are you in feed hold state? Can you post a screenshot?
I am using Gbrl and it is in the ‘Idle’ state. I will post a screenshot
I think I am an idiot…the ‘move by’ was set to .001 on the windows machine, so it appeared as though it was not moving. I changed it to .1 and verified that it is in fact moving.
