I am sure someone is going chastise for my lousy research and then point
I am sure someone is going chastise for my lousy research and then point me right to the answer but I searched everywhere and could not find…
What is the connector manufacture & PN for the “green” 4 pin DC power connector on the Smoothie’s VBB.
I suppose I can use 2x of the two pins types that come in the kit but Id like to not have the chance of plugging them in wrong.
Is it this jack table - Google Search
https://docs.google.com/spreadsheets/d/1bT7xw4z405cyhR7MyXegm4-C2oinxpVefuf3KV13v_A/edit#gid=0
Holy Crap … very nice.
Many thanks…
@Arthur_Wolf I wonder (tongue in cheek) if there is an error in the spreadsheet.
The given part no. for VBB power input on row 23 is:20020006-G021B01LF which resolves to a 2 position female connector and it is the same part # as listed for the “big MOSFETS” row 27.
Is it supposed to be OSTTJ047150 or 20020006-G041B01LF which I hope is a 4 position version of the same thing.
Or did you intend to use 2x two position, if so the qty is listed a only one.
Coincidentally my Smoothie came with enough 5mm connectors to populate the board +1, should that +1 have been a 4 position by any chance :)?
@donkjr afain 20020006-G021B01LF is the connector that is used to connect to both the VBB and the Big mosfets. The male part differs though, as the mosfets are angled at 90 degrees.
@donkjr Yes, you are supposed to use 2x2. And we don’t provide one of those ( the 5V one ) by default.
