I am testing a Smoothieware based Azteeg x5 mini, and Viki2 LCD on my Eustathios. The motion platform is amazing. I can run 50% faster than I could with my Azteeg x3 mini before I begin to see chatter on decel and quick moves. My only issue is I cannot seem to get the heated bed and hot end to heat up. The display on the Viki2 shows that it is enabled and heating… but the temp never rises.
@Tim_Rastall I tried on the viki2 and via simplify3d. I grabbed the latest firmware file from the Smoothieware builds, and the config from the github for the azteeg sample.
I’m assuming you’ve verified the hotend,bed, and thermistor pins are correct? I poked around that config, but of course am not much use yet other than to make sure nothing obvious is out of sorts there. Crazy timing of posting this. Was just thinking about posting to see who all has gone smoothieware for their board. Good luck! Hopefully someone chimes in.
