I am trying to run some GCode on the Smoothieboard SD card by pressing
I am trying to run some GCode on the Smoothieboard SD card by pressing a button (eg pin on the smoothieboard)
Can anyone help with the config for the smoothieboard to accomplish this.
I have tried the following with no luck
switch.playgcode1.enable true
switch.playgcode1.input_pin 1.28
switch.playgcode1.output_on_command play /sd/test.gcode
Thanks in advance for your help
Alexander
