I am trying to upgrade my firmware to Sailfish but ReplicatorG reporting the following:
IOException retrieving version file at http://download.replicat.org/updates.xml
When I browse to that URL nothing is there.
Any ideas how to handle this?
Thansk
http://www.sailfishfirmware.com/ has the solution…
Just to complete what @Nathan_Walkner was saying, you can find that option under File->Preferences->Advanced. You should see Firmware update ULR: on the top of that popup to be able and enter what Nathan posted
I don’t think we are talking about the same thing. The Update Address you specify has already been changed. The IOException is not referincing the http://jettyfirmwar… URL but http://download.replicate.org/updates.xml.
The Sailfish Docs specify that the firmware runs on MightyBoard rev E, G & H. Mine board says “FF _CreatorBoard_Rev D 20140320” Does this mean Sailfish won’t work?
Yes it does use the atmega2560 but the Rev is D, not E, G or H as the indicated in the manual that am using. I
http://www.sailfishfirmware.com/doc/install-hardware-reqs.html#x32-790006.1
