I am using laserweb with Openbuilds ACRO, and I cant to increase the size of a SVG file to be “Laser Cut”. No matter what size I change, its always engraved at the same size. Any help?
In Laserweb is shown at some size, but when engraved is engraved in a different size
Does the laser head http://move.thw correct amount when you jog? If move 100mm in any http://axis.and measure the distance moved http://is.it 100mm?
When I jog 100mm, the head moves 47mm
Thanks! I changed the $100 and $101 settings and it worked.
