I am using repetier-host with RAMPS 1.4 and Marlin 1.1.0-rc7
Something weird is happening with the extrusion rates. If I boot the ramps, then go straight to a serial connection and issue
G92 E0
G1 E100
Out comes 100mm of filament. So I know the steps are right.
Then if I fire up repetier-host, and extrude 100mm, out comes around 50-54mm
I can see that it G91 switches to relative, then G90 back to absolute, but still, if I issue the commands above from within repetier-host, I get half what I expect (this is without the hotend).
I checked the eeprom settings that repetier host sees, and the the extruder steps per unit match what I upload from arduino-ide
I have a problem with severe under extrusion, so I am wondering if this is what is causing the problem, or it is just how it works.
Repetier-host was downloaded about a month ago, so pretty new.
Is there a setting somewhere that overrides what the steps setting is that I am missing?
