I am working on a mashup between diagonal rods from seemecnc and the diagonal
I am working on a mashup between diagonal rods from @seemecnc and the diagonal rod end from SheepDog of thingiverse. I will be posting the design on the SeeMeCNC forums and thingiverse soon.
I think this means I am free to modify and distribute the design. I am a bit new to actually posting things on Thingivers. This is what the Griffon license info says.
Griffin 3D Delta Printer by Sheepdog is licensed under the Creative Commons - Attribution - Share Alike license.
@NathanielStenzel
Yep. That license basically means give them credit and make the same deal on your derivative.
Any assistance I could get in fixing up the STL file for public use would be greatly appreciated.
I used MeshLab to paint everything black and then paint what I wanted white. Next, I removed all black triangles from the mesh. This got rid of the hidden structures from the STL file. I removed the old files and uploaded the new ones. I hope this works out for everyone.
Version 2 is out. This time it uses the diagonal rod from SeeMeCNC modified by my own SCAD.
Version 2 is printing on my printer right now. I might be printing it a bit too fast though. Some curling happened and one diagonal arm is in a cast (about 1.5-2" of sturdy stake). I will test the fit in the sturdy stake soon after it prints.
V3.0 needed sanding inbetween the prongs. Added some more space between them, rounded some things out a little more and enlarged the peg just a slight bit. V3.1 is not tested, but is posted.
