I apologize @jlauer if this is not the best place to post bug reports. Just let me know where to post it if there is a better place.
The first time this happened, I thought it was a fluke, or I did something wrong. But then it happened again, so I took a picture of the screen.
What happened was I was jogging the machine around, both with my jog dial and with the onscreen buttons. I zeroed the machine. I also used the touch plate widget to set zero (which by the way, I would love if it remembered my touch plate thickness if I’m logged in - I have to type that in every time). Then, after moving around a bit with the jog dial, I went to move the bit down in Z using the onscreen button, and it started moving really far and not stopping. It did this earlier but moving up in Z. Since I had to use feed hold and was forced to reset, I lost all my G92 setup. I had to use feed hold before it tore into my stock material since there is no limit switch in that direction!
I know the picture isn’t that clear, but if you zoom in to the upper right you can see that I hit the -Z button and that the Move by is set to 1. But if you look in the GCODE that was sent, it sent a G91G0Z-100. -100!
It also seems to be that even though the “1” is pressed and was working earlier, if I go and re-click that “1” that it will reset this moveby amount back to the correct “1” amount.
Anyhow, since this is a particularly dangerous bug, I felt obliged to point it out.
