I cant connect from my Samsung Galaxy S2. The APP runs smoothly, but when it tries to connect, using several baudrates, no cigar !!
The printer is a Wanhao i3
Anyone ???
Anyone ???
Did you read the faq already? http://gcodeprintr.dietzm.de/FAQ.html#debug
I can’t see anything useful… I actually got it to connect once, but not since…
try to enable “debug logging” in the options, then reconnect and send me the console log -> long press on the console -> send email
@Niels_Ostbjerg does it work meanwhile ? If not please send me the console output so that I can help you to fix the problem. Thx
I found it to be unstable, so I will stick to the good old SD card.
But thanks anyway
Thanks for the feedback. Sounds like the connect finally worked ? What does “unstable” mean (App crash/print errors/disconnects)?
