I can’t seem to issue a @play command from pronterface is it possible I’m missing something in my config file that would allow me to play a .gcode file from the sd card
you can use the pronterface SD menu to run files from the sdcard.
Does @version work ?
What does @ls /sd/ tell you ?
not all versions of pronterface support @
@Wolfmanjm The latest one does though right ?
@Alex_Krause Are you using the latest version of Pronterface ?
I will have to look when I get home tonight… I’m using pronterface that was supplied with my smoothie 4xc most the files on the sd card have a modified/creation date in April of this year but without actually being on my computer no way for me to tell right now
@Arthur_Wolf @Wolfmanjm sorry for the late response I just now had a chance to play with the laser again it looks like it was my fault in the syntax of issuing the command I added a space between the last / and the file name for the path. I’m sorry if I have wasted your time I just miss read the instructions on playing from sd card. Thank you for the help guys I appreciate it
@Alex_Krause Glad you got it to work
